Hangar neighbor Bruce was up so I asked him to help me get prop on...have done it myself but much easier with two.
Snugged bolts down in an alternating pattern and torqued to an end value of 65# per manual. Used a 3/4" crow's foot....extends ARM of wrench by 1"...see new calculation...61.59# gets you 65 pounds/feet.
Had to remove safety wire and 970-3 washer on bottom shroud bolts for prop hub clearance. Will need to re-safety these lower bolts tomorrow along with prop bolts,
