Brief Description: add spacer to see if shake goes away
Yesterday's test flight had a shake or shimmy when rolling out on RW. I thought it might have been flat spots on tires from sitting so long. Today I looked more closely at nose gear fairing. Lots of free play in the fairing against the nose strut. Put this rubber spacer in temporarily to see if the shake/shudder goes away. If it does, I will come up with a more permanent fix.
