N144GP Lancair Super ES
Lancair Super ES
3 BID to half of cowling inlets
Applied very thick micro to gap/crease between foam insert and old cowling inlet.
Then applied 3 BID to cowl inlet foam; applied peel ply
Will do opposite halves later this week. Then super-fill and bodywork it all.
Cut foam at split line and applied release tape before doing first lay-up. Will split cowl halves and trim first BIDs before doing opposite halves.
Epoxy is taking on the red tint again...due to neoprene seals in epoxy pump. Almost out of epoxy.....
Lightning (EAB-LSA) Home
Lancair Super ES Home
4433
163
Bodywork - misc.
Elevators
Firewall forward
77
163
Flying - test flying
1070
Garmin 3X Touch pane
139
256
Garmin GMC 507 Autop
Gear and wheels
Horizontal Stab
75
148
298
Move
Research, prep shop,
Speed Brakes
Vert Stab - Rudder
136
166
393
Wiring
53
126
