N144GP Lancair Super ES
Lancair Super ES
begin work to modify cowl inlets
5.75" diameter at front...about 5.375" on inside. Orig. FG ES cowling was 5". Chuck Hess did 6".
Super-glued to cowling, cut out hole, shaped.
This will close in IV carbon cowl to be closer to original ES FG cowl. Chuck Hess did this and picked up 10 knots and CHT went up to 320 or so.
Will add some thick micro, 3 BID, then bodywork and prime.
left side - in rough
both in, rough shaped, ready for 3 BID
right side marked prior to cutting
Lightning (EAB-LSA) Home
Lancair Super ES Home
4433
163
Bodywork - misc.
Elevators
Firewall forward
77
163
Flying - test flying
1070
Garmin 3X Touch pane
139
256
Garmin GMC 507 Autop
Gear and wheels
Horizontal Stab
75
148
298
Move
Research, prep shop,
Speed Brakes
Vert Stab - Rudder
136
166
393
Wiring
53
126
