climb at Vx..85; primary alt and battery now fine; work on aileron and rudder trim after re-rigging L aileron; temps good...CHT's in low 300s at WOT - 6500' and ~1250 EGT; radios still noisy with background noise; VP phases still goofy; worked with AP in TRK mode, ALT hold; VS; GPSS turn at SEG; could not get AP to function from AFS...setting?; good landing
still have oil leak at remote filter - will contact Airwolf tomorrow fixed COM2 squelch and background noise, I think get XM settings straight and get refresh signal...works! MAP-SETTINGS - XM and Nexrad ON; Aerotronics Plug and Play not!
tighten spinner and wheel pant screws; polish spinner with stuff from Gary in hangar across the way
adjusted H-Yellow fuel pressure range up from 28 to 32. Had alarm when I advanced mixture on approach
