Research how to grease prop hub. Had tried this last week and didn't feel it went right.
Need to work with upper fitting and corresponding lower fitting on opposite casing half. Pull one fitting and shoot the other. (I was doing front to back pairs and that doesn't work)
For example....top fitting-front half at blade 1 matches with bottom fitting-back half for blade1. Pump grease until it comes out other side (open fitting)
Aeroshell #5
Also work on changing VP engine settings for Fuel Flow and Oil Temp to match AFS. Goal was to eliminate nuisance engine alarms from VP
