Brief Description: correct items from inspection & test flight
cap brake reservoir front nose fairing to lower cowl install stand-offs in FWF; zip tie wires safety rudder turnbuckles reroute wires at ELT panel - rudder bellcrank pass on re-doing front elev idler bolt...really hard to get to with the washers required. Bolt end is even with outside edge of elastic nut...torque dealed...will watch inspect elevator, rudder and aileron controls; check torqued on all nuts replace lower rudder hinge bolt with bolt +1/8"inch longer; open up slot in rudder skin for wrench access. sand cowl joggle micro... ready to be re-cowled research ALT charging circuit and review in place wiring. Looks OK...will do another test flight and make sure primary ALT is coming on line and charging. Will troubleshoot from there if needed.
