N144GP Lancair Super ES
Lancair Super ES
install clips to hold tow bar
found these rubberized spring clips at ACE Hardware...about $3/pair. Good to 1 1/8" tube. Main shaft is about 1 5/8".
Have some larger spring clips that I will add to the bottom end if needed. Seems very secure right now.
Put a velcro pad under the bolts at the lower end.
tow stored with clips
2 clips to Elev torque tube cover
pretty cool... I think they will work
Lightning (EAB-LSA) Home
Lancair Super ES Home
4433
163
Bodywork - misc.
Elevators
Firewall forward
77
163
Flying - test flying
1070
Garmin 3X Touch pane
139
256
Garmin GMC 507 Autop
Gear and wheels
Horizontal Stab
75
148
298
Move
Research, prep shop,
Speed Brakes
Vert Stab - Rudder
136
166
393
Wiring
53
126
