N144GP Lancair Super ES
Lancair Super ES
set up jig to balance elevators separately
rough estimate using left over aileron lead is that I will need to remove 2 add'l pounds of lead from each side; over and above what I drill out Monday.
set up 3" corner braces for elevator hinge jig
R elevator hung after 4 holes drilled
used AN3 bolts...low friction
Lightning (EAB-LSA) Home
Lancair Super ES Home
4433
163
Bodywork - misc.
Elevators
Firewall forward
77
163
Flying - test flying
1070
Garmin 3X Touch pane
139
256
Garmin GMC 507 Autop
Gear and wheels
Horizontal Stab
75
148
298
Move
Research, prep shop,
Speed Brakes
Vert Stab - Rudder
136
166
393
Wiring
53
126
