N144GP Lancair Super ES
Lancair Super ES
heat/defrost system
Exterior valve is on-off. Inside valve is mix between heat and defrost. Will need to add an additonal cable to control this inside mix valve.
Sceet 6 from outside tee down to heat muffs on muffler (future date).
Scat 5 inside to run ducts. Need some more engineering/thinking on the running of the inside Scat.
inside valve
inside valve installed - tight!
tee to exterior valve
Lightning (EAB-LSA) Home
Lancair Super ES Home
4433
163
Bodywork - misc.
Elevators
Firewall forward
77
163
Flying - test flying
1070
Garmin 3X Touch pane
139
256
Garmin GMC 507 Autop
Gear and wheels
Horizontal Stab
75
148
298
Move
Research, prep shop,
Speed Brakes
Vert Stab - Rudder
136
166
393
Wiring
53
126
