Brief Description: Cooler exit plenum comes together
The oil cooler exit plenum design has gone through several changes but has finally come together to provide a slick 1.4 ratio exit. I cut out all the parts needed and superglued them together the same way I did on the air filter box. I then laid up 2 plies UNI around all the joints. I did notive however that the oil cooler cutout on the firewall was not exactly centered which means the exit plenum won't exit exactly parallel to the cowling. Bummer. I will work with it and the cowl can always change if need be.
