I'm almost positive I'm going to need to add about 1/4" worth of height to the aft end of the filter box so it's a good time to go ahead and start adding micro to everything else. This will be the start of the finishing process of this box. Hopefully I'll be able to start carving out the foam inside this thing soon. However, I need it there for sanding the micro. I may also need to add a layer of glass on the inside of the box if the 2 plies BID is too flimsy. More later
