Brief Description: Power panel install micro and final spot fill
The DA sander is a fantastic asset to have. Great for sanding down spot filler on flat surfaces. I was able to use it to final contour the last of the spot filler and primer before final primer goes on. I was also able to install the newly painted power panel on top of a bed of micro that will allow a much more flush fit to the console. This time, however I will add a small bead of silicone around the border along with the 4 screws in order to keep things from flexing too much when using the panel over and over again. :)
