After the final round of primer was laid down, I noticed that the area that ramps up into the air intakes wasn't perfectly uniform. A little uneven if you will. I litterally have almost nothing left to do that isn't major work until after the avionics crew leaves this weekend so I paced around the fuselage looking for small ez jobs. I used Z-grip to fill in these low spots I found and faired them in as good as I could although it inevitable when sanding a concave surface to NEVER see perfection. It will need 1 more round of filler on one side to get it acceptable (as if it isn't already)
Finally I decided I didn't want the avionics crew to show up and see a dusty airplane so the hole fusealge got a soap and water damp rag bath in prep for tomorrows big day! AVIONICS!
