I was able to contour both shields to be almost completely identical. Pic 2 shows the correction i made to bonding the shield slightly inward by adding more micro outward to create a new shape. Looks pretty good so far. Finally, I am able to get a solid 15 degrees up while having 1/16" of a gap between the balance weight and shield. PERFECT. After adding a little more micro I will do final contouring to get them totally identical and we'll call em ready for primer :D
