Building Integrity
Date:  8-21-2014
Number of Hours:  5.00
Manual Reference:  ch 22
Brief Description:  Running more wires
This Saturday is going to be HUGE. Harrison Avionics is coming by to wire up the airplane. We are calculating 2 weekends to get is completely finished so by Saturday Night, things are going to look Awesome!
Now look, until I move this bird to the airport, I cant put the wings on which means I'm running out of things to do!!!! I decided to go over the wiring diagrams and see if there was ANYTHING else I could do myself to move things along faster on Saturday. I found that I could do the following:
1. Power and Ground wires ran for Passenger USB port
2. Power and Ground wires for the Cabin Lights
3. Power wire for Starter Button
4. Ground wires for VPX to Main Grounding Buss
5. Power and Ground wires run for Landing Light
6. Added a few Adel Clamps for cleaner, tighter pathways
I may have forgot a couple things I did, but running wires cleanly and crimping correctly takes TIME and it's time you'll spend either now OR later. Rest assured you WILL spend time on your wiring, so do it right the FIRST time :)
More Ground wires run
Panel wires ready to hook up
More panel switch wires
