Building Integrity
Date:  6-6-2012
Number of Hours:  0.50
Manual Reference:  ch 4
Brief Description:  Filling the nose gear window
I'm installing the EZ Noselift system which electronically gives a warning if the gear does not retract all the way. The plans say to glue a plexiglass window in the instrument panel in order to see the nose wheel for this same purpose however, no longer needing this feature, this will be the location of my air vent instead. Here I have filled the hole with dry micro and foam and will be glassing it after it cures
Foam filled
Foam filled
