Brief Description: Installed the Grips terminal strip
Installed the Grips terminal strip after securing the wires with lacing.
Drilled a hole in the right inboard seat rib and inserted a snap bushing. Ran the Push-to-Talk (PTT) wires from the terminal strip across to the hole in the right inboard seat rib then forward to the instrument panel area.
Drilled a hole in the left inboard seat rib for the cable that will run from the terminal strip aft to the VP CU. A snap bushing was inserted into this hole. I ran the Master Warning Acknowledge wire from the terminal strip through this hole and forward along the left side to the area of the VP Display Unit in the instrument panel.
