Brief Description: Ran Front Stick Ground to Aft Ground Terminal
Ran Front Stick Ground to Aft Ground Terminal block.
Secured Starter Cable with adel clamps and standoffs. One clamp holds the cable low aft of the center spar and the other clamp secures the cable aft of the trim servo. The cable secure and won't rub anywhere.
