Brief Description: Re-wired the Front/Aft grips at the terminal strip
Re-wired the Front/Aft grips at the terminal strip. As I went to bed, I visualized the wiring fix for my bird's nest. I removed the terminal strip from the fuselage and mounted it to holes drilled in a piece of plywood. I mounted cables for the front and aft grips to the board using adel clamps in approximate locations of where they will be mounted in the aircraft. From here, I cut, crimped and shrink labeled the matching front and aft wired to their terminal locations. The results were much better.
