John (Jack) Clark's Web Site
RV-A8
Crimped pins on Switch Panel plug wires
Crimped pins on Switch Panel plug wires after getting the crimper back from Vertical Power. This should be the end of power wire crimpng relative to the Vertical Power System.
Switch Panel connector
RV-14A Home
RV-A8 Home
5987
Aircraft Related
314
1351
404
Brakes
63
Cooling System
Cowl Flap
Cowling
146
354
Electrical System
157
311
158
Fiberglass
148
316
Finishing Kit
First Flight Prep
Flight Control Syste
75
118
Flight Testing
Flights
Forward Baggage Comp
Forward Top Skin
155
812
Heating System
Inspection
100
Lighting
Oxygen System
Painiting
Sensors
Testing
Ventilation
Windscreen
Wing Construction
1351
