Brief Description: Bent reinforcement washers for stick holes
Bent steel reinforcement washers for the stick holes using a 3/4' ID steel pipe. This gave me a 1" radius for the washer using the O.D. of the pipe. The fit on the control sticks is good. A friend will be welding these on the stick to strengthen the holes where the Grip cables will exit the stick.
