Brief Description: Fabricated a mount for the Aft Fused Terminal
Fabricated a mount for the Aft Fused Terminal. The mount may be used in the future for mounting the ELT. Platenutes were attached to aluminum angles and match drilled to alluminum sheet fitted to the space between the VP CU mounting bars. Using a benting brake, I bent the ends of the mount to give it strength and stiffness.
