Brief Description: Converted the Rudder Pedal WD steel parts
Converted the Rudder Pedal WD steel parts with a conversion solution from Stewart Systems. Applied it to the inside and outside of the weldments. The solution converts rust to an oxide and the final result is a part free of rust and sealed in a varnish that is paintable if desired.
