John (Jack) Clark's Web Site
RV-A8
Assembled Rudder pedal assembly
Assembled Rudder pedal assembly to insure the outside to outside measurements of the attachment angles are 15 1/4". Had toe grind the WD 827 brake arm cylinder to achieve the correct length.
Grinding Brake Arm Cylinder
15 1/4" outside-outside length
RV-14A Home
RV-A8 Home
5987
Aircraft Related
314
1351
404
Brakes
63
Cooling System
Cowl Flap
Cowling
146
354
Electrical System
157
311
158
Fiberglass
148
316
Finishing Kit
First Flight Prep
Flight Control Syste
75
118
Flight Testing
Flights
Forward Baggage Comp
Forward Top Skin
155
812
Heating System
Inspection
100
Lighting
Oxygen System
Painiting
Sensors
Testing
Ventilation
Windscreen
Wing Construction
1351
