John (Jack) Clark's Web Site
RV-A8
Drilled Rear Control Stick/fit sticks to Control C
Drilled Rear Control Stick. Reamed the brass bushings to fit the inserted bolts. Tapered and shaped the bushings and stick pivot points to fit in their barackets.
Front Stick and Bushing
Rear Stick and Bushing
Control Column Assembly
RV-14A Home
RV-A8 Home
5987
Aircraft Related
314
1351
404
Brakes
63
Cooling System
Cowl Flap
Cowling
146
354
Electrical System
157
311
158
Fiberglass
148
316
Finishing Kit
First Flight Prep
Flight Control Syste
75
118
Flight Testing
Flights
Forward Baggage Comp
Forward Top Skin
155
812
Heating System
Inspection
100
Lighting
Oxygen System
Painiting
Sensors
Testing
Ventilation
Windscreen
Wing Construction
1351
