Brief Description: Set the length of the F-829-2 pushrod
Set the length of the F-829-2 pushrod so that the front and rear sticks are parallel to each other.
Hung the control column in the fuselage after temporarily attaching the Aft Control Mount and setting the forward rod bearing at 1" from bracket to bearing center and the aft support bearing to 7/8" distance.
