Brief Description: Worked on Right Side Bottom Relieving Stresses
Worked on Right Side Bottom Relieving Stresses to get a better fit to the corner. Needed to open up the right forward corner, progressively removing material to get some mobility for shaping. Used string to pull the corner into shape for the complex curve of the front corner. Applied 2 plys of glass to the front transverse cut to hold the sections in relative position established with the aluminum strips and clecos.
