Brief Description: Installed Aluminum Strips for Backing to Corners
Installed Aluminum Strips for Backing to Corners where the complex shaping is needed. Using several overlapping strips worked best fir making a backing that was sturdy enough to lay clay against but not project below the desired curve lines.
