Wired the EIS System. This included running a wire from the Backup B Fused Panel to the EIS System fast-on terminal that I had mounted on the forward side of the bulkhead that forms the well of the baggage compartment. Four of the eight terminals were interconnected to provide power to the system's related equipment. This includes the Manifold Pressure Sensor, the EIS Module itself and both of the Capacitance Fuel Senders of each tank. Two of the terminals were wired for the data from each tank. And the remaining two terminals will be used to handle grounding of the the equipment.
