Brief Description: Moved the avionics terminal bar down 3/4".
I had thought that it was time to put the fuselage on its legs and to mount the engine. This ideas, for the better, were stopped for the need of some Aeroshell 5 grease for the gear bearings. Putting the fuselage on the gear would make working inside the fuselage more difficult due to the added height. It is already an effort to reach and manipulate inside the fuselage over the rails.
I ordered the grease and felt stalled for the lack of the grease. I could have worked on other tasks but all of them seemed to be too intermingled with other tasks that I could not become motivated to start. Many of these tasks could be classified as straightening or improving already completed installations. I must have been getting into the often mentioned builders' duldrims that occur when there doesn't seem to be much progress for all of the effort being expended. It has been so long since I worked on the aircraft that I find I have to spend alot of time just mentally organizing what needs to be done. Working on a regular basis, I pretty know what needs to be done the next day and the mental schedule just flows.
Today, I settled on just moving the avionics terminal bar mounted in the baggage compartment on the right side dowm 3/4 inches. This was done to improve the spacing between the terminals and to decrease wiring conflicts.
