Brief Description: Changed the Heater Fan Switch Installation
Changed the Heater Fan Switch Installation in order that it rotate during use. To do this, I needed to form the hole in the switch panel to have straight parallel side and curved ends to match that of the switch. I drilled the ends to a 1/4" then filed the sides to size.
