Brief Description: Installed the Dual Magnetometers
Installed the Dual Magnetometers after installing four aluminum rivnuts. To do this, the holes in the aft deck were drilled with a #2 bit and each rivnut was pulled using a rivnut tool. Used #8 x 2" brass screws to secure the boxes. I installed industrial strength velcro between each magnetometer to them from moving relative to each other as the were secures to the aft deck.
