Brief Description: Drilled Mounting Holes in the Magnetometers
Drilled Mounting Holes in the Magnetometers because the pre-drilled holes are centered in front of the 9 pin d-subs connections. This would be alright for a single installation but for the dual magnetometer installaion new holes need to be drilled on each side of the original hole. To do this, I made a template so that I could drill similar holes in each end.
