Brief Description: Ran Battery Backup Wires From the Right Aft Side
Ran Battery Backup Wires From the Right Aft Side fused terminal that receives power directly from the Primary Contactor. These wires will allow me to bypass the Vertical Power Control Unit should there be a failure of the unit. This also allows me to run the avionics directly off of the battery in any situation, such as IFR, where an interruption of power will cause a need to re-boot a piece of equipment vital to safety of flight. The Battery Backup wires will be used with the Audio panel, the G-430W, the SL-40, the transponder (Backup A), the Boost Fuel Pump, an several pieces of equipment the will be running off of the Backup B fused terminal.
I installed my first BNC connector on the RG-400 cable. It went quite well.
