John (Jack) Clark's Web Site
RV-A8
Ran Autopilot Servo Wires
Ran Autopilot Servo Wires from the servo locations, through the spar center section, to the forward cabin.
Drilled holes in the seat ribs for the passage of the antenna coax cables.
Replace and re-routed the Pitot Heater wire from the Control Unit. It was too short and it needed to be moved to the left side.
Wire to Roll Servo
Pitch Servo Wire Crossover
Pitch Servo Wires (Extra Green)
RV-14A Home
RV-A8 Home
5987
Aircraft Related
314
1351
404
Brakes
63
Cooling System
Cowl Flap
Cowling
146
354
Electrical System
157
311
158
Fiberglass
148
316
Finishing Kit
First Flight Prep
Flight Control Syste
75
118
Flight Testing
Flights
Forward Baggage Comp
Forward Top Skin
155
812
Heating System
Inspection
100
Lighting
Oxygen System
Painiting
Sensors
Testing
Ventilation
Windscreen
Wing Construction
1351
