Brief Description: Mounted the ADS-B to the Mounting Panel
Mounted the ADS-B to the Mounting Panel using nutplates and AN-3 bolts. Attached the panel to the mounting angles using #8 screws.
I'll need to reroute the power cable from the contactor to the power distribution terminal. This will better secure the cable as well as move the cable further from the ADS-B box.
