Brief Description: Connected the Rear and Front Throttles
Connected the Rear and Front Throttles using a string through the previously drilled holes. The string will show points of interference along the path of the Connecting Rod. These areas will be removed. The throttles will be moved throughout their full range of motion to insure no bulkhead interference with the movement of the rod. Once interference in prevented, then the rod will be tested in position.
