Brief Description: Made Spacer For the Front Throttle
Made Spacer For the Front Throttle to move the throttle outboard. While trying to install the rear throttle connecting rod to the front throttle, it became obvious that I had to move the front throttle outboard otherwise the connection rod would be at the inboard edges of the F-805 C-AL bulkhead. I am using a single front and rear throttle and the single throttle is smaller and has less width than a full quadrant used with the usual aircraft engine controls. Therefore, without the spacers, the throttle lever is too far inboard relative to the position of the connecting rod at the rear throttle attachment.
