Brief Description: Holes for the Rear Throttle Connection Rod
Holes for the Rear Throttle Connection Rod were opened in the bulkheads leading to the Front Throttle using a combination of a carbon burr and sanding drums on the Dremel Tool. The initial holes were opened using a step drill bit.
