Brief Description: Riveted Under Wing NACA Vent to Right Wing
Riveted Under Wing NACA Vent to Right Wing after I made some shims for the inside surface of the NACA vent. These shims were small pieces of aluminum for the rivets to pull against as the shop head was formed. This way the pulled rivets would not pull through the plastic. I used CS4-4 rivets.
