Moved the Wings to the Hangar using a 12' x 6' trailer from U-Haul. The wings were transported one at a time laying flat on cushions and secured with straps.
Once at the hangar, the blue vinyl film was removed from the wings and paper was used to seal the ends from critters. There were a few places of light corrosion noted. This was most often seen along the edge of the film and was most likely the result of sweat dripped on the skin during fitting of the wings the fuselage. I plan to remove these areas of corrosion by using aluminum polish. If that does not work, I'll surface convert the areas. This will definitely take care of the light corrosion.
