Brief Description: Prosealed the Under Wing NACA Vent to Rt Wing
Prosealed the Under Wing NACA Vent to Rt Wing after drilling, deburring and dimpling holes that I will use to rivet the vent to the wing. I will put some shims on the surface of the vent against which the rivets will pull. This will prevent the pulling of the rivets through the plastic vent.
