Brief Description: Riveted the Inside of the Baggage Door
Riveted the Inside of the Baggage Door. The inside rivets of the baggage door need to be riveted in place to insure that the door contour is set as close as possible to the shape of the exterior fuselage. To do this, Tim climped into the fuselage (the first to be insde the fuselage) and pulled some rivets while I held the door in place from the outside.
