Re-Did the Tips Trailing Edges. I did not like the results and appearance of the attempt to align the trailing edges last night. I re-cut the edges and re-glued them. But this time, I used some West System 206 Slow Hardener that gives about 20 minutes work time at 70 degrees. This gave me about10-12 minutes at 92 degrees. But this was enough time to aply the epoxy and clamp the edges into place. To thicken and to give some structural support, I had mixed some glass microfibers into the epoxy.
