Brief Description: Enlarged the Hole for the Flap Control Rod
Enlarged the Hole for the Flap Control Rod until the Left flap control rod moved freely with out contact with the holes edges.
I adjusted the linkages on both Flaps Control Rods to align the flaps with their respective aileron. The right flap aligned well. The left flap has some interference from the inboard aft tip as it contacts the fuselage. I'll have to trim it some more before I will be able align the flap with the aileron. I will also need to roll the leading edge of the right flap so that it properly tucks under the wing top skin. It does not have the right geometry to not spring up and catch/bind the top skin on both the inboard and outboard sides of the flap.
