John (Jack) Clark's Web Site
RV-A8
Opened Fuselage Hole for the Flap Control Rod
Opened Fuselage Hole for the Flap Control Rod to avoid contact between the rod and hole edges throughout the whole range of motion of the rod.
Adjusted the flap control rod laength in order to align the left flap with the left aileron that was in the neutral position.
Lt Flap Control Rod hole to flap
Flap Motor Power
Aileron and Flap Aligned
RV-14A Home
RV-A8 Home
5987
Aircraft Related
314
1351
404
Brakes
63
Cooling System
Cowl Flap
Cowling
146
354
Electrical System
157
311
158
Fiberglass
148
316
Finishing Kit
First Flight Prep
Flight Control Syste
75
118
Flight Testing
Flights
Forward Baggage Comp
Forward Top Skin
155
812
Heating System
Inspection
100
Lighting
Oxygen System
Painiting
Sensors
Testing
Ventilation
Windscreen
Wing Construction
1351
