Brief Description: Sanded Rudder Bottom Fairing with 120 Grit
Sanded Rudder Bottom Fairing with 120 Grit after lightly spraying the fairing with some black paint. The paint helps to identify high and low spots while sanding. High spots are first to be removed and then the low areas will sand clean once the entire area is lever.
