Brief Description: Bent Left upper longeron forward section
Bent Left upper longeron forward section at 34 3/16" until I had a 1" deflection at the forward tip measured against the right longeron as a straight line reference. This required several attempts because the unbent side would not lay flat on the floor afterwards. When the longeron did lay flat, the side being bent would need rebending. This happened several times but in the end, the forward bent end laid flat on the floor and the distal end was 1" from the reference.
