John (Jack) Clark's Web Site
RV-A8
Aircraft Related
2-22-2007
Atached the Rt aileron push-pull tubes
Atached the Rt aileron push-pull tubes while the aileron was in the neutral position. The rigging tool was used to position the bellcrank in the neutral position per the instructions.
Rt aileron bellcrank
Aileron hinge-rod end attachment
Bellcrank neutrality tool
RV-14A Home
RV-A8 Home
5987
Aircraft Related
314
1351
404
Brakes
63
Cooling System
Cowl Flap
Cowling
146
354
Electrical System
157
311
158
Fiberglass
148
316
Finishing Kit
First Flight Prep
Flight Control Syste
75
118
Flight Testing
Flights
Forward Baggage Comp
Forward Top Skin
155
812
Heating System
Inspection
100
Lighting
Oxygen System
Painiting
Sensors
Testing
Ventilation
Windscreen
Wing Construction
1351
